Why would you need a repair place? We can walk you through troubleshooting and repairing your blower right here.Why would you need a repair place? We can walk you through troubleshooting and repairing your blower right here.
You can't post conmments that contain an email address.
As long as it has fire, all you need to do is: Check the fuel lines for cracks/breaks. If this is o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure the small screen in carb. is free of debris. If you still have trouble after this, then you will need to buy a carb. kit and replace all appropriate parts.
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
