Posted on Oct 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon mx318 u051 check ink (blk, col) yesterday I was print photo of 25 pages. Printer is regular print of 23 pages but left 2 page . show this error u051 check ink (blk, col), I am using ink tank.So please help .thank.
Anonymous
Level 3:
President:
  • Master 787 Answers
  • Posted on Oct 26, 2009
Anonymous
Master
Level 3:
President:
Answers
787
Questions
0
Helped
415203
Points
2913
Try to press and hold the resume button for 5 seconds.If this not help you need to replace the ink cartridges.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3300
Points
I get error message with MP-470 after simply changing the toner.
1helpful
My Canon Pixma MP220 is has an error code U051 Chk Ink Blk Col, but i have just refilled my ink cartridges
Using refilled ink cartridges will get this error. You have to reset the waste ink levels by doing the followin
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click “Resume” button and then release Both Buttons.
  5. Click “Resume” for four times then click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
5helpful
Check ink U051 col
hi...you can try to press the reset button in five second.,.,
2helpful
2answers
Erroru051
Canon MX300
Hi
It is ink low error U051
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
43helpful
3answers
Pixma mx328 check ink u051
The error usually came out after you refill ink on the black cartridge...there is no way you can make the printer work without resetting the ink cartridge..
Try to reset the printer using this procedure.. it will help.
1. turn off the printer..
2. press/hold the stop/reset button..and press/hold power button too..
3 while holding power button, release the stop/reset button..
4. then press the stop/reset button twice..
5. release power button..and wait until the power button lights a steady/still green and says "idle"...
6. open the cover...take out both catridges.. then turn off the printer.
7.put back the cover then turn on...
8. now put the catridges back.. and wait for some time to return to display menu... then try to print...
The printer may still prompt a "black ink volume unknown and color ink volume unknown" but don't worry that won't affect the operation of the printer. And you will able to use your printer, fax and scanner.
Do this every time you refill the ink of the cartridges.
If you find this solution helpful please vote on this on the YES below..thanks..
8helpful
2answers
MP 170 check ink
U051,U052,U053,U059 all are signal or Error is mean CHECK CARTRIDGE
The Fine cartridge may not be install properly,or the cartridge may not be the compatible with this machine.Install and appropriate the fine cartridge.
15helpful
4answers
Ink Error "Check Ink, U051, BLK COL"
power off
press hold red button
power on hold button
release red button twice
=beep=
all done !
old marine
old marine
ZJ Limited
ZJ Limited
