Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
How to reset the unbalance switches on mah3000aww
My washer went out of balance and now won't reach high spin speed on spin cycle, it will spins slow.
There appear to be three balance related buttons, a strut, a tub and an inertial switch, I have reached in to feel around and found only one button on the left side when facing the back of the machine.
Door locked and all other things appear to be working fine. Can you help this mom get the machine back to speed? I have lots of laundry building up in piles.
    Scholar:
  • 196 Answers
This sounds more like a motor control problem. You need to open the control panel and find the service sheet. This sheet will tell you how to run diagnostics and other tests on the machine.
Posted on Jan 15, 2008
6ya staff
SOURCE:
My maytag neptune mah3000aww spins slowly then reverses, then spins slowly. will not reach regular spinning speed. What is the problem?
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
Feb 18, 2015 | Maytag Neptune Washer Door Mah3000aww
The machine begins just fine half way through a cycle it stops. Sometimes it runs with no problem. One time we got a code of (UE) I think not sure.
UE = Unbalance Error. For bulky loads, use a lower spin speed. For regular cycles, use a larger amount of clothing per load, and / or a lower spin speed. You can load the drum with dry clothing up to the point where you are just able to reach your arm in to touch the back of the drum. Very small loads can cause more frequent off balance situations.
Mar 15, 2011 | LG WM-2277HW Front Load Washer
LG Tromm washer wont spin through the spin cycle and reads error ue. I have tried to balance the load several times and still get the same error.
This error generally happens when people try to run a bulky load, like a coat, rug, pillow, etc., using a high speed spin. For these loads, choose the low speed spin. After the cycle completes, if you think the clothes are too wet, power up the machine again but instead of choosing a cycle, just push the spin speed button until it shows the next higher spin speed (usually about 14 minutes will show on the display) and push start. The machine will usually be able to get to a faster speed now, as the clothes have some of the water spun out of them from the earlier low speed spin, allowing the machine to reach a higher spin speed without the Unbalance Error code showing up. Of course, you want to make sure the machine is on a solid floor with all the legs adjusted properly also.
Jan 02, 2011 | LG WM-1832C Front Load Washer
Screen reads UE? what is UE?
UE stands for Unbalance Error. If the washer has tried to spin numerous times, tried to redistribute the load itself between each attempt, and still not been able to get the load up to full speed without experiencing an off balance condition, it will finally stop and display the UE code. This is most often the case when a heavy / bulky item(s) are being washed and the spin speed is set very high. When washing these items, set the spin speed to low. The machine will most likely be able to handle that. If you want them spun out faster, then AFTER the washer has made it through the cycle on low speed spin do this: Turn the power back on. Without selecting any cycle, just press the spin speed button, selecting the next higher spin speed. Now press start, and your washer will just do a 14 minute or so pump and spin.
For super wet heavy loads, if you cannot even get the washer to go through a cycle on the lowest spin speed, you may have to wring a bunch of the water out of the clothes by hand before doing the 14 minute cycle thing.
Apr 11, 2010 | LG WM-2277HW Front Load Washer
Model#mah3000aww won't go into spin cycle...checked belt and its good.it rinses clothes but does not speed up when draining or go into high speed
take off the panel above the door,there is a micro switch next to the light put meter on switch and read it out,use a screw driver and push on switch while your checking for continuity,if that switch checks ok change out the enersia switch,take off just the right side of the boot and remove right side white cover and you can reach this switch
Nov 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE WHDRR418 top load washer won't spin at high speed; the washer does the complete cycle, and agitates in both directions and does physically spin, but it will not go into the 'high speed' spin that...
we can eliminate the motor and the switch since that part is working. sound like your timer might be faulty, timer make everything work in persistence cycles, if its goes bad sometime it tend to jump/skip cycles.
Jul 21, 2009 | GE WSXH208A Front Load Washer
After a wash cycle, the letters UE appeared in the timer window..
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
Jul 05, 2009 | LG WM2487H Front Load Washer
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Maytag washer issues
Could be just about anything. It's all designed to prevent it from spinning if there is a problem. If the motor is still turning, but never gets up to spin speed, check the out of balance circuit. There are two cabinet strike switches and an inertial unbalance switch. Or check the door latch assembly, it's possible for the door to lock enough to turn the 'door lock' light on, but not move far enough to actuate the 'spin enable' switch. Maytag has upgraded the motor/ motor control board for the older Neptunes. If the motor is not running at all, check that the main control board is sending power to the motor control board. If it is you need the motor/ motor control kit (just one part #) If the main board is not sending power to the motor control board, you need a main control board, but you still need to test the motor control board. Take a test cord and put 120 volts to the motor control board, the motor should start turning at 50 rpm (normal agitate speed) if it doesn't you would need the motor/ motor control kit as well.
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
831 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
