Having problems finding hardware for a metal evenflo crib. Lost track of parte to attach movable side rail to metal evenflo crib. need plastic track and screws.
1.Find and read the instructions carefully before doing anything. Become familiar with the instructions so that even if you do not remember everything, you have a basic idea of how to proceed before you start. Look on the manufacturer's website for directions if you have lost the original instructions. 2
Assemble the parts. Make sure you have all of the parts and all of the screws that are listed in the instructions, and that they are in working order. Lay out the parts so that everything is where you need it and you can clearly see all of the parts. 3
Set up the head and foot boards and attach any stabilizing bars. Some springs attach directly to the bed and some are movable, so you will either attach the spring board or you will attach the pieces that the spring board sits in if they are not part of the crib already. If the spring board is movable, put it on the setting that is the correct height for your infant (higher for newborns, lower for older babies). 4
Attach the back of the crib that is stationary and does not move up or down. The front part of the crib often is adjustable and lowers and raises back to a stable position. You may have to install rails for this part of the crib, then install the front portion onto the bars and then screw the bottom of the rails into the crib. 5
Put the mattress in the crib and make sure it fits. Test the crib by feeling to make sure that it is steady and not going to come loose. Make sure all of the screws and bolts are tight and that none are sticking out in any way. Make sure there is nothing that could hurt the infant such as any sharp edges or splinters
Start with www.evenflo.com
If they don't have it,you could try places such as www.productsamerica.com
New/used shops sometimes have cribs that have seen better days,but some of the parts are still good.
Hope this helps.
do you have a bar on the bottom of the side of the crib - if you do, all you do is push it in and the rail will come down. If you don't have this rail, then you are missing that part.
and enter the model number and date of manufacture. The parts list will display a list of parts and include the instruction manual which you can download for free.
Use the manual to find the screws you need. You can get screws at a hardware store or home center store.
Check out Evenflo's website: Product Support, Replacement Parts; you'll find out what's available & a free manual to download once you enter your model # & date. Good luck!
evenflo sells very limited parts - go to their website and click on product support and/or replacement parts. if they don't have them a found a super site that sells various hardware http://www.productsamerica.com/index.html
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here: http://www.pali-design.com/index.php?path=customer_services&template=faq§ion=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed To
convert a crib into a toddler bed you must loosen the two front gold
bolts left and right side of the crib and remove the dropside (the
front gate that goes up and down). After removing the dropside be very
careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail) To install a streight (toddler) rail
loosen the two front gold bolts left and right side of the crib and
remove the dropside, once you have removed the dropside replace with
the streight rail. Always be very careful and make sure you tighten
back your two gold bolts in the front.
