My Frigidire electric oven lock door LED flash for 10 sec and then give f1 error and start beaping. I checked temp sensor around 1100ohms. Door lock assemby was damaged and was removed long time ago. It was working fine after that. I replaced 2 shorted diodes close to two relays from board. If I push bake, broil or clean button, realy clicks. Nothing happens from all other buttons not even beep. I have removed the board and trying to troubleshoot. All relays and door lock switch is fine, I have tested them. I thint it try to lock the door when I turn it on. I can change components PCB. Please help me. Thanks
SOURCE: Frigidaire Electric oven model # GLEB27S7C
If you unplug the range and remove the lower rear cover on your left side you should see the motor with 2 switch's on it. There are 3 possibilitys with it. One of the switch's on the assembly is not working or the light switch for the door is not good. You also can disconect the lead to the motor and connect a power cord to it and that will unlock the door so you can check the dor switch also. if you do not feel comfortable powering up the lock motor then you should call a repair man. But one of the switches is not letting the computer know the dor is locked.
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
SOURCE: The self cleaning oven lock is locked but door is not closed.
It's time for service sounds like you have a bad oven door switch or the mechanical rod that engages the switch is not travelling back and forth freely. Anr repairs with the rear access panel off should only be performed by factory trained service tech's.
SOURCE: Oven door will not lock to clean
hi, these two codes together are signaling a EOC failure. the electronic oven control has failed and you will need to replace the EOC/clock. it is unable to initiate any commands because, it in a frozen state.
You can try to reset this control by unplugging the entire unit for 5 minutes. if the control continues to not reaspond to your commands, replace the EOC.
please rate and god bless:)
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
