Evenflo Aura Traditions Travel System Safari Trek Stroller Logo
Posted on Oct 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My friend gave me a evenflo travel system but the car seat is adjusted on the very top adjustment im to have my baby soon and need it adjusted for a new born but i can figure out how help please
Anonymous
Level 3:
  • Master 396 Answers
  • Posted on Oct 25, 2009
Anonymous
Master
Level 3:
Answers
396
Questions
0
Helped
121096
Points
1083
Just look for the manual online and use it congratulations
Need instructions for evenflo model 4531156
You can find the instruction manual for your Evenflo car seat here:
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=4531156&txSearchDOM=1/1/2013
You will also need the date of manufacture.
1helpful
Hi! I need help understanding how to adjust the ******** the evenflo Chase car seat as the adjustment is on the actual strap itself not below like most car seats.
Use te link below to inout your model number and date of manufacture to download
a free owners manual with directions on how to adjust the car seat. I couldnt do it for
you as you did not include the date of manufacture but it is easy to use their system.
You can save a copy of the manual on your computer for future reference.
Evenflo Car Seat Manual Lookup
How to adjust the car seats belt
Look for an I shaped adjustment band and move it to adjust the car seat belt.
I have a queston about my evenflo car seat
please look for an I shaped adjustment loop -= slide it to adjust and you are done.
We reinstalled our Evenflo car seat and now baby's head flops forward. How can we fix this?
First check the settings on the car base. Usually there are 3 settings so most likely the setting you adjusted it to is too high for your baby. You have to remove the baby form the car seat (smile), check the setting level (at the front of the car seat) and adjust accordingly. Good luck i hope this helps!
Model Number on my Evenflo On My Way Travel System - Need Cover
My used Evenflo On My Way travel system model number for the stroller is 4951F7. The model number on the car seat is 4951F7P2.
Question for you - Is there a front tray to snap on when not using the car seat? Mine is missing that part. Thanks.
Need the Plastic retaining rivets that secure the sunscreen
I went to babies r us and they helped me or you can go to this website and put in the car seats info and try to order it here https://plweb.evenflo.com/replacement_parts.aspx
9helpful
Evenflo aura travel system
I hope this information helps:
1) There are harness anchors (metal clips) located on the bottom of the seat. Push these up through the slot to the front of the seat on both sides. To do this, you will need to pull them toward you, and then turn the anchors to fit through the slots.
2) You should be able to remove the bottoms of the straps at this point. Remove them, then pull the tops of the straps through the slots. (You will need to remove the buckles during this process.)
3) Slide the straps through the slot you need for the correct harness height.
4) Replace the buckles in the correct positions.
5) Replace the bottoms of the straps into the harness anchors.
6) Push the harness anchors through the padding and back into the bottom of the seat. Clip into place.
Top Evenflo Baby Gear Experts
ZJ Limited
ZJ Limited
Jennifer Rock
Jennifer Rock
john h
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
