That means you don't have a good DIgital INput (get it?) signal or bitstream. Correct the source's playback or connection.
It's on page 37 of the manual.
Cam gear in mechanism would be broken and causing that problem. Camera will take apart in detail and it is qualified tech job to fix it, take it in local camera repair shop for fix as it is not user level repair.
The v900 has some years on it. It will need the heads cleaned ,possible torque adjustment or replacement of the video drum unit. To clean it is only $40 at Larry's electronics [email protected]
i have the JVC MiniDV Digital Video Cleaning Cassette. I began having trouble when I was shooting DV24P and when I went to playback I noted audio dropouts. I'm using SONY Premium DVM60 tapes. I began having Head Cleaning Required message. I have ran the Cleaning Cassette and the message disappears, but even trying a brand new tape, switching to DV playback i get the error message. Luckily, the shoot i was on the master audio was being captured by a secondary device and we were able to simply use the video from my camera. Since then, I was able to play & capture both the video & audio previously recorded in HDV30P and I didnt receive an error message. Now though I cannot record any DV audio without dropouts. When I tested just moments ago, I was able to record HDV and both video & audio were clean, but during playback I still received the Head Cleaning message. Is the record head different from the playback head? Can you manually clean the heads by removing the plastic door cover with a lintfree cotton swab and rubbing alcohol (obviously disconnecting and removing all power & powering off prior to cleaning), the same way any previous machine heads were cleaned in our stations? I think I may have got a batch of bad tapes that may have gunked up one of the heads some where and its getting missed by the cleaning tape. Is is possible that the head has been scratched, and will require replacement. If yes, is there any way to look at the head and detect this?
while your monitoring the sound when recording it cuts out or while you playback the tape it dropps out? if it's noticed during playback it's one 3 things. the heads are dirty, the tape tension is low or the heads are bad. send it to video tech service in sacramento. that guy is super cool.
