Cisco 871 Router Logo
Posted on Oct 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We are converting from DSL to Comcast cable, both have a static IP & VPN to another site. Is there anything we have to do other then change the addresses?
Anonymous
Level 2:
Scholar:
  • Expert 54 Answers
  • Posted on Oct 25, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
54
Questions
0
Helped
19034
Points
160
As much as I know, you're correct. All you need is just change the static Internet IP from Comcast on the VPN configuration for local and remote gateway address.
2answers
How to change ip address
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
You can change only dynamic ip address by resetting the modem or switch off modem and switch on again.You cannot change static ip address.Static ip will not change even if you reset the modem or router or switch off the modem and switch on it.To check Ip address you can visit the site Ip-Details.com
1helpful
3answers
I need to change my ip addres, i have an acer aspire with linux
This computer as any once assigned a IP address is locked to it
Vpn site to site
you need to create an IPSec tunnel between the router and windows server 2003 (run secpol.msc). From the dlink router, you need to set the IP address of the VoIP gateway as part of the LAN that is included on the VPN tunnel. Since it is the server 2003 that has a static IP, you need to initiate the connection from the Dlink router.
Sonicwall site2site vpn issues
please select nebios option in hq site tz190 firewall.
VPN Connection problem with DSL
contact your ISP and ask them to enable IPPAssTHROUGH on your system.
make sure the ports::
TCP 10000
UDP::500, 4500 should be open
2answers
I want to create site to site vpn with sonicwall tz170+ 2003serv
Complete documentation is available on the below link
http://www.sonicwall.com/us/support/3134.html#heading_3139
Cannot connect with SonicWall VPN Client with GigaFast EE420 R
sonic is sitting on the gateway. so dont matter where u are still u cant get outside
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
