Question about E-Machines W3052 PC Desktop
My w3052 emachiens desktop computer card readers wont work
I bought a w3052 emachiens desktop computer but the card readers don't work. it crashed and we reinsalled windows xp and put in a new hard drive. since then they haven't worked.
    Problem Solver:
  • 13 Answers
Visit the support section of the eMachine website to get the software that controls that function.
Posted on Oct 25, 2009
6ya staff
SOURCE:
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
New hard drive/how to install Windows
the new hard drive has to be Formatted using the format command. look up dos format command or a utility program. then you have to reinstall Windows ?(whatever you had i guess) on the pc. any drivers disk for that pc needs to run after you format the hard drive and before installing the Windows operating system. exactly how depends. go on the HOW TO search site to find the exact steps -
Nov 20, 2013 | Dell Inspiron Computers & Internet
Hi, I have a Vivitar 3750 camera. My software disk is for windows XP. I bought a new computer Windows 7. Is there a free download for the software for window 7? Thanks
To my knowledge there is not. The software you have for the camera as you found out is not compatible. Windows 7 will have imaging software built in which leaves the only problem being getting the images from the camera to the new PC's hard drive. This can be accomplished using a memory card reader, the computer then looks at this reader as an external hard drive. You can then download the memory card files to a folder on the computer and ask Windows 7 to open the file folder. This should one selected file type thumbnails of your pictures. Personally I don't use the camera software at all. I use Photoshop to handle my photo's that and a memory card reader so I can use any one of my four digital cameras. I'm sure Photoshop 7 has imaging programs in the early versions it was called "Paint"
Mar 04, 2011 | Vivitar ViviCam 3750 Digital Camera
System crashes completely. just freezes and never recovers. for some odd reason, when i try to run the windows repair, it crashes as well giving me the blue screen of death. i have three other hard drives:...
You are probably correct in thinking it a motherboard problem, its sounds like the disk controller on the motherboard id faulty.
There are a huge range of motherboards to choose from.
The mounting holes on the motherboard will match the desktop mounting plate, these are standard configurations.
Stick with the well known brands and with the functions that suit your requirements.
My choice of brands are Gigabyte, Intel, MSI.
If you are into gaming and video editing etc. go for a motherboard without a built-in graphics card and purchase a separate high end graphics card.
Nov 14, 2009 | Acer Aspire M5641 PC Desktop
Have a canon powershot A40...can download pics on other computers through camera and scanner wizard, but have a new refurbished machine that is great, but flashes the ''can not detect camera''. The sound...
Invest in a USB card reader to read the CF card from your camera (around $15). Your camera was made before picture transfer protocol (PTP) was develeoped, which is what allows the camera and scanner wizard to work. With the card reader, you put your card into it, and your computer 'sees' the card reader as another drive on the computer, like a flash drive.
Aug 14, 2009 | Canon Cameras
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
Have windows xp . bought SD card reader/writer cd-35.when i try to put info on sd computer says to format.i do then it says can not complete formatting
the problem is in the card check it on some other's computer or card reader
how do you like the solution rate it
Oct 14, 2008 | Computers & Internet
How to tell if computer hardware will be sufficient for Flight Simulator X
From the specs you have supplied, your friends computer should be able to run FS X just fine.
Matt
Apr 16, 2008 | Computers & Internet
Sd card
First you need to see if the computer reconizes the reader, to do this you double click on the computer icon on your desktop, then look to see if there are any drives other than your hard drive and cd roms. If the computer does not see the reader then you may need to download drivers. As to how to get the drivers it depends on your setup if the reader was installed in the computer when you bought it then you will want to go to the computer manfactuer website, if you bought the reader seperatly then you should have recived a disk with it if not go to the website of the card reader manfactuer.
Hope this helps.
Carl
Feb 07, 2008 | Microsoft Windows Vista Ultimate Edition
New video card keeps monitor blank
you have to reprogram your pc. or try changing the jumpersetting. disabling your onboard video display. hop this solves the problem.
Jan 10, 2008 | E-Machines W3052 PC Desktop
E-Machines W3052 PC Desktop Logo
128 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
