What are the factory settings for ws55908
Normal factory settings are for normal video and audio. Convergence factory setting will default all convergence setting requiring a full alignment of which I would not recommend. Factory settings in the service mode will change the geometry, gray scale, and others, that's another one I would not recommend. Tell me why your asking, and the problem your having?
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Settings
RESTORING
FACTORY SETTINGS
initialization
The top of my screen is too high and I would like to bring it down. Also, I feel the other settings maybe off so I would like to find out the factory numbers to put them back to original default.
I did try VPOS under the JUNG heading. The picture jumps but will not move down up or to any location.
any help would be appreciated.
