Kodak EasyShare V1003 Digital Camera Logo
Posted on Oct 24, 2009
The shutter is stuck and when i take apicture its blurry
Blurry focus of benq c850
Possible that you gat a slow shutter speed. Or your camera might be getting faulty. When the shutter gets damaged then the blurry focus wont change unless its fixed. The four main causes of blurry photos are:
  1. Out Of Focus
  2. The subject moves while the shutter is open
  3. The camera moves while the shutter is open
  4. Depth Of Field is too shallow
Unless its just technical or hardware you will need to visit a technician. or replace the Shutter.
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Nikon D60x Blurry night pictures
Try switching to Shutter Prority (S) with a fast shutter speed.If the light is not so good, up the iso to 800 to gain that faster shutter speed..
You do not say the lens in use ? if VR, make sure its switched on or use a tripod.
Hope this helps
Beeps when turning off and pics are blurry
try replacing the battery, cleaning the lens, or fixing the lens
2answers
Blurry flash shots
Try increasing your shutter speed (maybe 1/250)
Fuzzy images
Hey jjbeanwink,
This is a very nice lens, and is unlikely that your blurry images are caused by the lens. The most common cause of blurry pictures is that the shutter speed is set to low. A general rule would be your shutter speed should be at least 1/60th of a second while handholding the camera. The bigger the lens, and the higher the magnification of the subject you are using the faster the shutter speed you should use. If camera shake is the cause of your blurry pictures you could also try using a tripod. Another common cause of blurry images is subject movement, and one solution would also be setting a faster shutter speed. Another solution is using the flash to stop the action instead of the shutter speed. Of course manufacturers do occasionally make a bad product and that is why there are manufacturers’ warranties. If you just purchased this lens you could have an authorized service technician look at the lens and see if there is anything wrong with it. I these suggestions help!
Sincerely,
Allan
Go Ahead. Use Us.
Canon EOS Rebel G
it seems you have a dirty lens,sticky mechanisms prevent smooth movement of lens cause by excessive moisture,blurry foto cause by fungus on your lens,pls note dissambling ang cleaning your lens requires patience and rigourous training.
Help
Do the pictures have lines across them as well as being blurry? If you see the lines then your shutter is stuck open and it will require repair. The shutter has to close for the image sensor to properly record the image. If they have no abnormal lines on them, are they "out of focus" blurry or is it more of a streaked motion blur kind of thing? If you do need to get the camera repaired you should check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Blurry picture
I have this same problem. If I shut the camera off then on again it clears up. Someone from Fuji said that this is because the Auto-Focus is stuck on. They advised to half push the shutter button to release the auto-focus.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
