Compaq Presario C700 sled off bed. Getting error message "Replace Hard Disk 1" Can I fix instead?
IF YOU ARE ABLE TO PULL OUT YOUR HARD DISK, THEN RESET IT AGAIN IN THE SLOT, TO BE SURE IT IS BEING PLACED TO ITS RIGHT POSITION, THEN ON YOUR SYSTEM AGAIN, IF IT WORKS, FINE IF NOT...COULD BE THE CONNECTOR TO HARD DISK IS CRACKED WHILE IT WAS DROPPED..
Your hard drive came loose i would take the cover off your hdd and remove and then place it back in should fix it but if not then you need a new hdd.
