I tried to unlock my SGH-A707 phone by this code #7465625*638*59258259* (the unlock code 59258259 was given by the store in California were it was bought) , but what came out is "Phone Freeze SIM Unavailable Please Contact Service Provider". Can you kindly help me unlock my phone. Thank you very much
when i turn on my phone it says enter pin. after i have put in my pin, straight away it say's 'phone freezed' and then say's enter password. don't know a password to enter. tried ringing 02 and samsung but they can't help. do you have any idea ?
i have lost the booklet with the unlock code and it wont let me used the phone it says 'phone froze' what shall i do??i have lost the booklet with the unlock code and it wont let me used the phone it says 'phone froze' what shall i do??
please help me to unlock sumsung e350 imei 352008016828532please help me to unlock sumsung e350 imei 352008016828532
AnonymousMar 29, 2014
My son gave me his Samsung rush phone when he upgraded. The phone worked fine at his house, but when I got back to my nursing home, I tried to use it but it says I have no phone service. And the service isn't due to expire till the 14th of April. I can't hear the phone ring in or anything. Any ideas on what it could be? My son thinks I accidently hit a button that disabled the phone part, if I did, do you know what button that can do this?? Any help would be welcomeMy son gave me his Samsung rush phone when he upgraded. The phone worked fine at his house, but when I got back to my nursing home, I tried to use it but it says I have no phone service. And the service isn't due to expire till the 14th of April. I can't hear the phone ring in or anything. Any ideas on what it could be? My son thinks I accidently hit a button that disabled the phone part, if I did, do you know what button that can do this?? Any help would be welcome
AnonymousMar 31, 2014
I turn my phone on n it tells me to unlock my phone it takes me to a spot where it says enter lock code ???? please helpI turn my phone on n it tells me to unlock my phone it takes me to a spot where it says enter lock code ???? please help
You can't post conmments that contain an email address.
FOR PEOPLE WITH PHONE FREEZE ON SAMSUNG- the #7465625*638*code# is not needed when you have the phone freeze just follow below. I know how frustrating this was and i got it done by myself by experimenting since everything cant be googled that easily. i figured i can help anyone out. this has worked for 5 phones that i have done my self so 5 for 5 YESS!!! This is as satisfiying to me as watching micheal jordans final shot! any ? contact me at [email protected] ok i figured it out. for all those people that have gotten the dreaded phone freeze om samsung propel a767 or any other samsung phone so far not sure about touch screen. first look for a local unlocker in ur area or somewher that can provide the codes and get the unlock code and phone freeze code. mine was only 20 for both and took less than 24 to retrieve. email me for his info. insert sim that you want to use (tmobile). you get the screen which says phone freeze. type in the freeze unlock code which was given and the press the att logo/menu button. **YOU WILL NOT BE ABLE TO SEE THE NUMBERS YOU ARE TYPING SO KEEP TRACK OF WHAT YOU INPUT** after you have entered number and pressed button then you will get a network lock screen. this is where you type in ur unlock code. type that in press confirm and BAMM!!!! you are now able to use tmobile sim
All you have to do it type: #7465625*2877#
That will unlock the phone to use on any carrier; The problem you are
faced with now is that the a707 only accepts 3G sim cards. If you are
using T Mobile just ask them they should give you the code. If not, you
are just out of luck as there are new firmware upgrades for the a707 at
this time. GOOD LUCK. This is not illegal nor is it illegal for them to
lock a phone
Aug 04, 2009- here you go this should work took me a bit to find 0.for most samsung phones hope it helps 1. remove your simcard 2. type *2767*3855# ALL DATA WILL BE LOST.
If the phone is locked with firmware then the code wont work.
insert a different sim to your phone then input this code: *2767*3855# wait till it reboot now your phone is open next input this code: *7465625*638*00000000*00000000# next again input another code: #7465625*638*59258259# finish now your phone is permanently unlock. feel free to use any sim...... ok!
* if the second code you input, didn't work go dierictly to the last code ok......
phone freezes samsung e350
phone freeze
