You're apparently using a lens with an aperture ring. Turn the ring to its smallest aperture (largest f/number). If the ring has a lock, lock it in place. You can control the aperture from the camera body, the same was as with a lens without an aperture ring.
Turn the aperture ring to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
This might sound dumb, but are you sure the lens is clean of dirt or oil, this will cause that kind of effect. If not, how old is the camera? If it is under 1 Year, I can have it repaired for you under warranty, my fee would 35.00.
Turn the aperture ring on the lens to its smallest aperture (largest f/number). Lock it in place if there is a lock. You control the aperture from the camera as you would with a lens without an aperture ring.
Set your aperture to the maximu f stop number, that means the minimum aperture, and your camera will work. Take out the lens and align the ring to set it to the minimum aperture. I shall paste a link down here so that you can refer in detai.
The problem is, that you have a lens witch has an aparture ring on it and some exposure modes needs it to be fixed on the smallest aparture (e. f22). When its done the camera should not say fEE no longer.
Hi sarahlopez,
Make sure the lens is mounted properly and if you are shooting in auto that the camera is set to AF and the lens to M/A. Try that first and then let me know if you were shooting in any other manual modes, or if you had recently changed the lens, OK?
randy320sgi
That usually means that the lens you have mounted on the camera is not set to its smallest aperture (ie 22). It needs to be set that way so that the camera can control the full spectrum of aperture positions when shooting in one of the auto program modes.
Make sure the F-stop ring on the lens is turned to the minimum aperture setting. Usually 22 or 32. The camera won't allow you to shoot unless it is. It will try to warn you by flashing the FEE code.
The camera requires you to set your lens aperture at the minimum setting, usually orange coloured. I.E. f22 f32. Nikons control the aperture through the camera, not setting the ring manually like old style SLR's
