Question about Bunn NHB Coffee Maker
My bunn coffee maker is leaking water out of the
My bunn coffee maker is leaking water out of the back or bottom every time i make a pot of coffee
  • 189 Answers
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Posted on May 19, 2010
  • Official Brand Answer
  • 3,100 Answers
Probably can call bunn for the replacement part at no charge due to recall
Posted on Oct 31, 2012
6ya staff
SOURCE:
Bunn coffee pot leaking bottom
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Oct 02, 2014 | Bunn Coffee Makers & Espresso Machines
How to fix a leak on a bunn NHBX coffee maker
Aug 09, 2014 | Bunn NHB Coffee Maker
Our bunn coffee pot trips the gfci and leaks water out of bottom of unit, why?
the water maybe wetted some electrical parts or ur tank heater faulty
Jun 24, 2014 | Bunn NHB Coffee Maker
Bunn 10 cup home coffee maker
It sounds like a seal/gasket is defective causing it to leak. Please locate the model and date code on the bottom of the brewer and contact customer service for troubleshooting and replacement options.
Feb 05, 2010 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
My Bunn coffee pot leaks water theres always a puddle of water under the pot.coffee pot is over half full
It sounds like you have a broken seal/gasket. Please get the model and date code located on the bottom of the machine and call customer service. The machine has a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a discounted price.
Sep 13, 2009 | Bunn NHB Coffee Maker
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Water leak on a Bunn coffee maker model B8W, leak only when brewing a pot of coffee
Where is the leak coming from? If it is from the back of the unit or the bottom then it is cracked and you will just need to replace the coffee maker. If it is leaking from the top then it is a seal issue in the water valve that brings the water from the tank and into the coffe filter and into the pot.
Apr 26, 2009 | Refrigerators
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
734 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
Marvin
Marvin
littlechum55
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
