I got my Vu cu920 from my exwife and she forgot the security code for the phone. My question is there any way I can get the master code for the phone for free?
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code.
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
If you forgot or do not know the reset code for your LG Vu here is the way to do it. Works, just did it to mine.
To do a factory reset with your LG Vu cell phone, you must enter the Test Menu, the instructions are below.LG Phone Problem and solution
1. Dial 277634#*# on the keypad to access the Test Menu 2. Select Factory Reset 3. Select Yes 4. After the factory reset is complete, you must restart your phone for it to take full effect.
go to the menu then the setting menu then tap more and hit the security menu and a list should appear. at the bottom should change codes and tap that and then security code pin 1 and pin 2 should appear. jjust tap security code and enter the code you want it should set it to that code.
