If you are attempting to use Recovery and this is happening, Most likely you have a corrupted recovery partition....
If you are attempting to load Windows XP from A CDrom (Externally)
you will need to use an XP Cd that has integrated Sata drivers.. Windows home/pro 32bit does not..
Windows WiFi Fix, Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected. Windows XP: Click Start Right click on My Computer When a window pops up click on properties Click on the Hardware tab Click Device Manager Click the [+] next to Network Adapters Find your wireless card and right click on it. Click Disable Windows may warn you that disabling the device may make it stop functioning. Continue disabling the device. Wait 30 seconds or so. Right click on your wireless again and click Enable. Exit the device manager. Reconnect to your router. You should now be able to connect to the internet.
Windows Vista:
Click Start Logo Right Click Computer Click Device Manager Windows will ask you about opening Device ManagerClick Continue Click the [+] next to Network Adapters Find your wireless card and right click on it. Click Disable Windows may warn you that disabling the device may make it stop functioning. Continue disabling the device. Wait 30 seconds or so. Right click on your wireless again and click Enable. Exit the device manager. Reconnect to your router. You should now be able to connect to the internet.
The IBM Recovery Disk that comes with those laptops is set up for Windows 2000, not Windows XP Pro. The answer is No, you cannot use the IBM Recovery Disk for them, if you install Windows XP Pro.
However! You will have a recovery disk, because you will have the Full Installation disk for Each laptop. Windows XP Pro Full Installation Disk.
(Microsoft Users License states "One genuine copy of Windows per One computer" That means you need Two, genuine copies of Microsoft Windows XP Pro)
Hi, my guess would be a corrupt windows file. Usually running a check disk can take care of this problem, otherwise it may be that you'll need to reinstall windows (hopefully not).
If you have the Windows XP cd that came with the computer then you should be able to boot to it while turning on the computer (either by changing the boot order in the BIOS or by doing a one time boot selection).
Once you have loaded up the CD it should give you the option to install windows or launch recovery console. You will want to launch the recovery console and when it gives you a DOS prompt (Looking similar to "C:/") you want to type "chkdsk /r". That will run check disk and test your core windows files for any corruption.
If you don't have the CD an option would be to use a different computer with working internet access and CD burner to download the Windows Recovery Console CD for your version of windows and make a copy of it to use in the computer.
Well your explanation was clear but your should've not ruled out the hardware issue. if both computer suffered the same problem at the same time the problem could be within the Desktop itself. I have experienced the same problem with my HP when I move to my new house after 5 years. What happend is that during transportation the vibration lossened up the parts inside your computer. So what I did was I reseated all the parts inside the desktop and reinstalled Windows XP. Till now I have never had any problems yet.
Symptoms: After you run Microsoft Windows AntiSpyware (Beta) or other anti-virus/spyware/adware software, 1) you may receive one or more of the following interactive error messages:
Could not start the Windows Firewall/Internet Connection Sharing (ICS) service on Local Computer. Error 10047: An address incompatible with the requested protocol was used.
or
Windows Firewall settings cannot be displayed because the associated service is not running. Do you want to start the Windows Firewall/Internet Connection Sharing (ICS) service?
or
This application has failed to start because SPORDER.dll was not found.
2) Third-party networking products may not function correctly.
3) Computers may not be able to connect to the network because they cannot obtain an IP address.
4) You may receive the following error message when you are using Microsoft Internet Explorer:
Error 404: Page cannot be displayed.
Cause:
There are known spyware programs that install layered service providers (LSPs) on client computers to gather user data. When Windows AntiSpyware (Beta) removes spyware programs, it also removes the spyware-based LSPs. However, Windows AntiSpyware (Beta) does not restore any LSPs after it removes the spyware.
Resolutions:
How to rebuild the Winsock LSP chain on Windows XP SP2
How to rebuild the Winsock LSP chain on Windows XP, XP SP1, and Windows 2000
__________________ Bob Lin, MS-MVP, MCSE & CNE How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
Try Scanning your Computer For Computer Viruses.
then re-install Windows XP.
Your files will remain intact, if you select to leave the hard-drive As it is ( rather Than Format it ) or setup on a different Partition.
Backup your Valuable Docs/Files First.
Windows re-installation will replace any Missing-deleted Corrupt Files.
hope This Helps you.
