Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
Posted on Oct 23, 2009
How do i remove the demo mode from my sony bravia tv have a thing on either side called motionflow appearing
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7556
Points
9
Press the menu button on the side of the TV, not the remote, for several seconds
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12840
Points
13
How can i remove the demo mode off my sony tv KDL-55NX810
47helpful
2answers
Turn demo mode off on Sony Bravia TV 40"
Here'show to turn off the demo mode,
Power ON the television
(Use remote Commander)
1.Select "TV" mode (not AV, demo mode can't switch offwhen you are in AV)
2. Press the "home" button on the remote.
3. Select "settings"
4. Select "set up"
5. Scroll down to "factory setting" and restore them.
6. When it asks home or shop display select "home".
21helpful
Demo mode keeps on popping up on sony bravia. how do i permanently remove it
hi,
you can exit the DEMO MODE by the following setup.
1. select "TV" mode (not AV, demo mode can't switch off when ur in AV)
3. select "settings".
4. select "set up" .
6. when it asks home or shop display select "home".
ok
26helpful
I bought a Sony Bravia EX7/40 today. It's store demo mode appears every 60 seconds. How do I turn this off
  • Press the home button on the remote to go to the cross bar thing.
  • Choose settings
  • Look For set up
  • Scroll down to factory setting and restore them.
  • After that it will go to set up mode when it asks home or shop/display select "home".
    This will disable the Demo Mode.
7helpful
The wording "demo mode motion flow" is at the top of the screen and won't go away. how do i get rid of it?
You need to go into the TV menu and turn it off.
Press HOME, then select s_xmbs_set.icon.png > Picture & Display > Picture Adjustments > Motionflow > the desired option.
Good luck and let me know if this helps!
321helpful
3answers
Press and HOLD (5 sec) the MENU button located on the SIDE of the TV. A message will appear; (Demo Mode: OFF).
7helpful
How to get rid of demo mode motionflow wording on sony bravia television
Try some of these solutions:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  1. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Store Mode is ON.
for Bravia's.. To turn off the demo mode, press and hold the MENU button on the TV for more than 10 seconds. The message Demo mode: Off will appear on the screen.
Let me know if this helps.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
