unplug, take out battery then hold power button for 30 seconds then plug back in and turn on if the3 laptap gos on without the battery you need a new battery
This actually does sound like the battery is low on charge. A battery which is quite low on charge will still light the headlights and run many other electrical accessories, but will not engage the starter (which requires much more power than other accessories).
I would start by making sure that an electrical device, such as interior lights, glove box lights, trunk light or something else has not been left on. Then carefully jump start the engine. It is also possible that the battery might need to be replaced for not holding a charge.
Are there any lights or indications on the battery itself that might tell you if the battery is good? I had a laptop with a similar problem and it turned out to be both a bad battery and a bad "power brick". replacing both fixed my issues. Also, try holding the power cable at the point where it connects to the laptop and push to the left or right. A friend's laptop would only start if you held the power cable to the left. Otherwise, it sounds like a mother board issue. Sorry.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Sounds like your battery is just too dead, has enough juice to light up the system for a minute but cranking drains it and if it wont charge then deff fried, you could try removing the battery and starting the car with cables to confirm the starter still works. If a bettery is too dead then when you are jumping it, it takes to much of the power just trying to get through the battery.
Sounds like a battery low on charge. As the bike has huge pistons compared to a 4 cylinder machine, it's harder for the starter motor to turn and needs more power.
Try charging the battery, on a proper charger not an optimate battery conditioner type.
When starting turn any ancilaries (lights, heated grips etc) off.
How long did you let it charge, when the device is completely drained of power it may not turn on at first when you connect it. Let it charge for a little while and come back to see if it fixes it. Failing that, your probably going to have to contact apple for warranty help.
sounds like someone needs a new battery.. if the battery will not take a charge, or jump start, it usually means the battery cells are either dry or unusable, replace battery and try again
