STICKS on cycle, wash, etc. If manually moved ahead, it skips cycles. model fdb635rfs4.
Do you mean the timer or control dial sticks. If so then it may be the timer mechanism itself.
Make sure that when you are skipping a turn on the timer that the machine is actually performing that particular task of the cycle. For example if the timer gets stuck before the drain cycle, and you manually skip forward to it, that it actually drains the water out.
If so then it is most likely a worn timer mechanism which sticks.
Ash
Testimonial: "interesting theory. Just know it doesn't work, have had problems with everything we bought from Sears, and WON'T DO THAT AGAIN. Thanks for your help"
