there is a possibility that you may have pulled off the power switch, to motherboard Connector.
This will be at the bottom right hand-side of the Motherboard.
You should have a 2 cable connector for. pwr/sw Power Switch. hdd/led Hard-Drive led. rst/sw reset Switch.
Check those First. if you didn,t remove the power lead, before attempting any work. you may have arced a current, and damaged the motherboard Or PSU. check the Fuse In The Actual plug lead. to determine the actual power Switch, without a multi-meter. remove the power lead, from the Computer. remove the power/sw connector From motherboard, And Bridge the power/sw with A plastic jumper Block. then replace power lead, and should boot up. If it does the fault is the actual power switch faulty.
Mike @ Compurepair.
