The empty water light on my TDC32 dryer wont go off even when it is empty please can you help
The black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
I pulled my dryer out and pulled the clear pipe and the black pipe that runs up the back of tryer off and cleaned them out and it is working now so i think i must have had a bockage. the water light has now gone off and the dryer is now drying clothes .julie
I noticed this is a common question, i have the same problem on my TDC40 so i read the manual and it says " the empty water light will stay on solid. this is normal, only when the empty water light is flashing will indicate that the water tank needs emptying" so i guess there is not a problem if the TDC32 and the TDC40 are similar in design, I am not an enginner but i had problems with my TDC40 and stripped it down to fix it therefore i know some minor problems and can only help with "SOME" questions.
Please check the switch where you reomve the tank it needs to be open and tell the dryer it is empty
SOURCE: hotpoint dryer TDC32
i had this problem but it is NORMAL. only when the empty water light is flashing it needs emptying, i thought there was an internal problem but like i say it is normal to stay on solid throughout your drying and even when you just switch it on. i found this out in my manual
I have exactly the same problem with my brand new CTDOOP and this prevents the element from heating up and hence - no drying!
I have the same problem with hotpoint aquarius - empty water light won't go out even though there is no water to empty - doesn't dry clothes because it won't heat up!
Empty light wont go out, Dryer not heating up. Both Stats replaced with new. Is there a water light switch somewhere that is malfunctioning. Any ideas would be appreciated.
Frustrated :-(
i have the same problem with my creda dryer modle TCR2 only had it for 10 months and only used it about 20 times the empty water light stays on all the time so the dryer will not heat up can anyone heep .julie
