Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
My whirlpool cabrio dryer will not turn on and the sensor light stays on.
    New Friend:
Thermal Fuse. Part #3392519
Check video here
Posted on Jul 30, 2013
  • 491 Answers
SUUNDS LIKE TERMOTSTATS HAVE BLOWN.
Posted on Oct 22, 2009
    Guru:
  • 1,738 Answers
A slim chance try unpluging the dryer, or throughing the breaker to the dryer. If you sensor light still comes on then it it high limit senor open.. To me it sounds like it is your elements could cause that or your vent was plug up.
    New Friend:
I'm trying to replace the motor from my Whirlpool Cabrio (WED6400SW1) dryer. The motor is impossible to remove from the blower. I can't break the motor away without stripping the plastic blower nut that connects to the two. What do you recommend I do at this point. I'm thinking that I should try to seperate the two by cutting the plastic connection and order a new blower fan.
Posted on Nov 28, 2009
5 Suggested Answers
6ya staff
SOURCE:
teresawatts6
SOURCE: sensoring stays on and dryer will not work on
there is a fuse in the back of the dryer next to the bottom on the left hand side it has wires plugged into it cost $11.00 to fix don't call whirlpool they don't have a clue
Posted on Sep 07, 2011
Anonymous
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
DOUBBLEJ34
  • 523 Answers
SOURCE: Whirlpool cabrio gas dryer does not turn gas on to
first change the ignightor if its a glow plug
Posted on Jul 01, 2010
rickead1
Rick Ead
  • 1998 Answers
SOURCE: mywhirlpool cabrio WED6200Sw0 dryer doesn't turn
whirlpool cabrio infamous for blowing out control boards check with a multimeter to see if you have power going into the machine and trace the lead power wire to the control board most likely it is your main control board hope this helps
Posted on Jul 14, 2010
Dryer doesn't start. Sensor light stays on.
Does your drum light cut on and off with the opening and closing of the door
Apr 27, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio dryer won't start - the sensing light stays on
An EXTREMELY helpful technical guide is folded inside the console housing.
WARNING: It is for appliance techs, DO NOT do the voltage/resistance checks if you are not well-versed in troubleshooting appliances! BUT, it does include putting the dryer in diagnostics mode and checking the sensors.
Post back any error codes you may get.
Oct 22, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Sensoring stays on and dryer will not work on Cabrio dryer
Sep 05, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Jan 11, 2018 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Drum will not turn
Check three things.
First off is that the brake is disengaging and is not holding the drum in place.
Next check the motor to make sure that it is not frozen.
Last but should be done first is look at the belt to make sure that it is not broken or has come loose
Jun 02, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio steam electric dryer has sensor light on and does not work
Apr 18, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
2,557 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
