Yes, thermostats vary on what the thermostats control if it is just heat you will need two less wires. Do not always go by color go by manufactures wiring diagram. You need to find out your common wire normally it will be marked with a C on most cases find out through manual what letter marking it is then use a ohm meter to check your common to each wire there should be continuity.
The only time a ohms setting should be met are on contact that you use low voltage to switch on 110 voltage or transformers that turn high voltage to low voltage which should also be specified in manual.
