I have a navman N40i, when I plug in the car charger the charge light comes on, but when I plug the other end into the navman the charge light goes away & will not charge for me!
Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
Plug the unit into its charger using the USB port on the
bottom of the unit. The battery indicator light next to the power switch
should turn orange, indicating that the device is charging. Once the
light has turned green the charge is complete. If the light does not
turn on, verify that the car charger is plugged into a working outlet.
The motherboard has died and is costly to replace ( if you can even get one now) Often cheaper to buy anothert GPS If you do get an Altina from Marbella Australia, they have great service and backup and a damn good FAQ on what not to do
turn it off at the bootom of the unit then turn it back on via the same switch. then pug in the charger and it should turn back on. it works for me when it happens to mine.
Solution to get GPS Navman N40I working with Windows Vista. I solver the problem (most of it) by uninstalling the old activsynk witch was delivered with the manufactory CD. Then I downloaded from “http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center.mspx” Windows Mobile Device Center. After installing this software I connected my Navman N40I to my PC and waited to for the Mobile Device Center application to load. When it tried to gain partnership with my GPS I removed it. Voila, and the SmartST Desktop 2006 SE application was able to communicate with my GPS. Hope this will help you! Kind regards Mega A
Does the car charger cord plug into the cradle? or just straight into the unit (despite resting on the cradle) ? Do you know if anything else charges via the car charger?
