Return it! refilling cartridges often void your warranty. Not to mention the cartridges that come with the printer are usually 1/3 to 1/5 filled making you think that the new ones are over priced. Use original.
Open cpu cabinet. Refix RAM memory. Clean dust from all parts. Reattch ATX power connector from smps to motherbord. Pull cmos cell from motherbord for 10 minutes so all settings are defaults. REmove pci cards from pci slot of motherbord then check. Open processor fan and processor then refix both. Make sure motherbord not ground with cabinet cover. Then check if still problems then change ram .check RAM and motherbord separately .
Or reset motherbord settings to defaults you can reset with 2 methods. (1)Pull cmos cell from motherbord for 10 minutes so all settings defaults. (2)
Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put
jumper in 2-3 position and thne power up then again put pin in 1-2
position thne all settings defualts. Refix RAM memory.Clean dust from all parts. Open processor and processor fan. Remove pci cards from motherbord then check. Make sure motherbord not ground with cabinet. Let me know if you need further assistance.
open cpu cabinet .
check on motherbord corner side cable pin from power on/off switch to motherbord corner pin jumper correctly.
check on motherbord you find power on/off PIN jumper you cna ground it with any metal like screw driver. then if power on then you have to check that cable or still not start then you have to reset factory defaults settings of motherbord.
For thta pull cmos cell from motherbord for 10 minutes .
Then check.
did you find something out......email me @[email protected]... please... or do I need to call the 1-800 #??? no prob just get back to me if no prob.....
