The handle is normally the upper fixing point and there will be two screws at the bottom, probably Torx or Philips head screws. I am still looking for something specific to your model, but removing doors and splitting them is a pretty generic thing to do. On one of the images you posted There may be something hiding under that small rectangular tab, probably the upper screw fixing. Second image here https://www.fixya.com/support/t29803641-remove_inner_glass_from_oven_door_obi
Your image 3, clearly shows the same latches in the instructions from Whirlpool.
Usually the oven doors when opened just slide out of the hinges especially on whirlpool. Once you slide out the door you will have to remove the inner door screws as well as the handle screws and the screws around the sides of the door if there are screws there too. Then you can get to the glass. Then you should be able to replace or clean the glass.
P.S. On some models you may also find screws holding the door to the hinges. If so you will want to remove those too.
The video on You Tube will show you how to remove your oven door. You may need to watch it all of the way through to see your type of hinge. The video shows four different hinge types which are common and so covers most oven models.
I have a different model Whirlpool oven but if the door opens downwards then there are usually two smalll catches on top of the main hinges. Lift these up (they can be quite stiff) away from the oven, partially close the door and it should lift upwards to free the hinges.
Please take a look at the diagram if you think you want to do that.
if you still want to do it and need more details to disassemble feel free to email me. [email protected]
Usually open the door to the first setting where the door is 6 to 10 inches from the reame let it sit there and pull up and out . The springs are in the door and the hinge sits into a reciever in the range.
