My bike will start sometimes, and when it does it will either die like 5 seconds later or if it stays running it will die as soon as I give it gas what could be causing this???
Sounds as if you don't have any gas to give it! Turn off the tank fuel tap, remove the carburetor fuel hose, and place the end in a clean can or jar. Turn on the tap again--you should get a small stream of fuel running from the hose. If it just drips, turn off the tap again, unscrew the small bowl under the tap and remove the brass filter screen just above the bowl. Soak it for a while in carburetor cleaner, rinse in fresh cleaner, then put it all back together. Turn on tap again and check for fuel flow. If still weak, turn the tap to 'reserve' position--is the flow still weak? If so, remove the fuel tap bowl and place the can/jar underneath and turn the tap on again. If still slow, open the fuel cap up on top to make sure that tank vacuum is not stopping flow. If nothing helps, you will need to remove the tank, drain the fuel out and remove the fuel tap to clean the two tubes that are sticking out of the top. You may need compressed air to get this accomplished. Good luck!
