Disconnect everything in the back of the unit. reconnect only the cd to the imputs. also,just to be sure, disconnect all speakers(label them). fire it up,play a CD, connect the speakers 1 at a time. If the 1st works you have hope ,if not, try each channel individualy.The one that reduces volume is the problem-maybe shorted cable, bad speaker,or , God forbid-Bad amp Channel. good luck
do you have a technical school nearby? This is exactly what they teach. Find'em, use 'em.Your problem could be several things
depending on your electronic experience, check OP-Amps on pre 2, if the zone 2 mains work, that indicates pre amp out at least get to the main zone 2 amps. could be as simple as a loose PCB connection.otherwise, get a tech.
0
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Thank you for allowing
us to help, please respond with further questions and concerns
Spanish speaking
available for all problems
Before you leave
feedback, ensure that your concerns and problems are addressed completely with
me.
PLEASE do not forget to
award/PROVIDE "POSITIVE" FEEDBACK
Hello, thank you for
sharing your problem with us, I would personally be happy to provide the most
accurate and up to date information for you.
Here is a copy of your operators manual
http://us.lge.com/filedown.do?filepath=1000004174&fileName=PG60_manual.pdf
Solutions
Press the VOL (+ or -) button to adjust the volume.
If you want to switch the sound off, press the MUTE button.
You can cancel the Mute function by pressing the MUTE or VOL (+ or -)
button.
2. USE THE SOUND MODE OPTION BUTTON
Sound Mode: Selects the factory preset sound for
type of program.
3.
SOUND MODES
Multi Audio: Changes the audio language (Digital
signal).
SAP: Selects MTS sound (Analog signal).
4. PAGE 88 thru 95 go extensively into details regarding sound adjustment
thanks mrwtech but this did not help, just tried it and still the same issue persists: no sound on any channel but a distant one.
