Ebel 1087902 wristwatch Logo
Posted on Oct 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Ebel Sport Classique needs repair for the 181-1 movement Detent. What is the cost of repair and an overhaul for this 8 yr old watch?
Anonymous
Level 2:
Sniper:
  • Expert 61 Answers
  • Posted on Oct 21, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
61
Questions
0
Helped
70696
Points
170
Depending what all is involved with the overhaul and other repairs the low end for repair would cost around $375 and may cost as much as $600. Anytime I send a watch in for this kind of repair I expect a free estimate and you should too. If there is a cost for an estimate or if the estimate is around the $600 mark I realy feel you should get a 2nd detailed estimate from a different jewelry store/ repair center.
2answers
I need to change a battery on an Ebel Beluga. I took the screws off of the back, but I don't see a notch to fit a case tool into. How can i get the back open? TIA!:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjUr5fpzKODAxWrrYkEHUk5CRkQtwJ6BAgXEAI&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DNsO51niRkG4&usg=AOvVaw3cAlt5v_VcYq2mMw1bFCuo&opi=89978449
How change batery ebel sport classic
This is not a simple task.You need a watchmaker with knowledge of Ebel watches.The case is opened by removing the bezel and splitting the crown stem.The watch module then pulls out of the front of the case.This is not simple I advise you dont try.At www.rolexrepairs.co.uk they operate a postal service so your watch can be returned within 2 or 3 days.
Regards
I have a Ebal watch 1187141 and I am looking to buy links for it. Any suggestions. I emailed Ebel and they never responded. Garth
mcdevito75 here, hello garth, keep trying Ebel on line, Check on Ebay, or a small watch repair shop in your area for the links and to save on cost.
1helpful
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Ebel voyager automatic stopped needs replacement balance staff
An automatic watch can have many of the same issues as a wind up because that is what it is essentially. This means that you could have a main spring issue or standard maintenance issue. The watch should be overhauled and oiled about every 4-5 years.
1helpful
Average cost for an "overhaul"
I've paid $250 - $450 for my Rolex about every ten years.  The Ebel is another fine watch, and should cost about the same.  They come back looking like new.
Need a new stem. Can I purchase on and get it put on myself
You have to open your watch and find movement number. Use an eyeglass as the numbers are very tiny. Number is pressed onto one of movement plates and shoud be letters ETA+number.
When this is done, visit your nearest watchmaker shop and ask for stem for movement ETA+number. Do not tell this is for Ebel or you will be charged accordingly to brand name.
There should be no problems for supplying ETA stem.
2answers
Stopped running
Unfortunately watch service is often calculated based on the value of the watch, as insurance, and quality/cost of materials and spares and tools are factors. With the correct lubricant there should be no reason why a quality watch should need that particular job done so regularly, but a 4/5-yearly service is not a bad idea at all, as most problems with this sort of watch can be avoided with regular maintenance. Hope this helps :)
Top Ebel Watches Experts
ADMIN Andrew
ADMIN Andrew
Aron
David Kassin
David Kassin
Are you an Ebel Watch Expert? Answer questions, earn points and help others
