If the pressure switch detects either water or suds, it commands the
drain pump to continue. After 8 or so minutes, if it's still detecting
water or suds, the F02 error is displayed.
try the following :
1. Check Wire Harness connections -
2. Check Drain pump. , as water drains at a rapid rate
3. Check Drain pump motor - , as water drains at a rapid rate
4. Check that the Drain hose and Drain Pump Filter is clear of
foreign objects. – , run a cable through both hose assemblies (exterior and interior) and to check if blocked.
5. Check the CCU –.
6. check for kinks in the hoses, and the height of the pump if beyond what the manual recommends.
if okay then check the Pressure
Switch if stuck then run many Rinse and
Normal cycles with no detergent and if you still get this F02 error. checked
the state of the Pressure Switch’s Empty and Level 1 contacts which
intermittently reported correct water level condition (EMPTY and
Level 1). In all cases is contacts 11 and 14 (SUDS) continuously made
(connected) irrespective of water level, rinse conditions and the use
of no detergent.
Iremove the pressure switch and test it by blowing into the inlet
and check to hear the switch click, test the switch
blew into the pressure switch hose to clear the blockage,
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if
the unit is unable to drain then after 4 minutes it will display suds and then
F02. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
F02 is a drain error in your washer, if
other questions.
Kevin
other questions.
Kevin
