Overview for Lexmark 5400 series:
http://www.lexmark.com/publications/pdfs/2007/5400/en.html
See set up sheet (page 1):
http://images.lexmark.com/publications/pdfs/2007/5400/setup-sheet-en-es.pdf
SOURCE: how do i connect my lexmark x5470 with out cd software
This link has the driver for it.
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:549:0:0
Is that what you're looking to find? If that's correct, don't forget to rate the answer. Thanks.
If you mean cable, then it should take a USB cable.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if
you get in troubles, follow
the instructions below to reset and reinstall drivers:
Try to rebrick you printer by pulling out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds. This will reset your printer.
If that doesn't help, try to plug your printer into a different known working power outlet.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
