The person that I'm talking to sounds very quite. I called my voicemail to make sure it wasn't just a bad connection, but I could barely hear that either.
This phone has many different volumes to play with, one of them is the volume for, when your calling someone, simply, when you call someone, press the volume up button, and you should hear the person louder
It sounds like your speaker may be blocked or is going bad. Try to clean it out while the phone is turned off with a q-tip and alcohol. Make sure it dries before turning the phone back on.
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settingsthere click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it hope this helps
Hmmmmmmm.......I doubt your timing chain skipped. Possible bad coil pack.Wasn't running hot or nearly out of oil? If it's not a vacuum hose(large one)or fuel pump quitting, I'd say it's an internal engine problem. Can you get someone to plug a code reader into it? don-ohio
Check in the user book if there is a sensitivity adjustment for the sound recording. It is possible that the sensitivity is set too high.
It is also possible that there is something defective in the camera's audio circuits. In this case the camera would have to be sent to the manufacture service rep to fix the fault.
