Question about Whirlpool Dryers
Loaded clothes in dryer hit the start button and heard a big loud clunk. The dryer will not start now. Whirpool Dryer Model# LEQ9858PW0
    Scholar:
  • 52 Answers
This could be a lot of things but i always go with the odds. it sounds like the belt broke and the clunk was the belt tensioner letting go. depending on where the lint screen is, if it is on top, remove the lint screen and the two screws. grab and bring the top of the dryer forward and then up. a small screwdriver placed between the top of the dryer and the front of the dryer can expedite the process if the top does not pop up nicely because there are two spring metal clips near the corners of the dryer top. you should be able to see the belt. pull on it and it should be tight. if it is not, you need a new belt and further investigation to see what if anything caused the belt to break.
Posted on Oct 20, 2009
Testimonial: "Thank you so very much for this solution so I am going to go try to fix it myself."
6ya staff
SOURCE:
Got clothes out my dryer and turned the drum clockwise to get a lint. Heard a loud clunk noise and now it wont spin. Please help
check for a broken drive belt for the drum
the clunk may have been from the belt as it broke and hit the cabinet
Apr 07, 2015 | Dryers
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
Dryer was running with full load of clothes. Heard a loud pop twice, ran back to the laundry room and smelled like something burning. Turned dryer off, and now it won't start back. Also, the very top of...
Well it sounds like a sound I have heard... forgetting that I had a cigarette lighter in my pocket and having it explode from the heat in the dryer. But you say you heard two loud pops?
Once everything cools down, check again and report back... does the dryer not turn on at all? Does the light come on when you open the door? Does it buzz when you push the start button? Stuff like that.
Jul 27, 2009 | GE DBXR463EDWW Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Whirlpool LEQ9858PW0 Buzzes But Won't Start.
sounds as if wither you have a bad motor assy, or something haas fallen down into the "blower assy" preventing the motor form spinning.. in the back wher eyou tested your fuse, just to the left of that you see a large tubular housing (rounded on bottom", thats the cover for the blower , i believe its 3-4 screw holding it on, nad also the 2 screws visable when you remove the filter assy, the housing will pull off( you may need to wiggle it abit) and hopefully youll find a sock or something jammed in the blower assy
Jan 16, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Dec 14, 2008 | Kenmore Dryers
Dryer appears broken, heard LOUD sound from other room (broken belt?)
gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Apr 14, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Electric Dryer
More than likely the belt for the drum or the door switch is faulty. What is the model of your whirpool?
Mar 05, 2008 | Dryers
Loud noise
Got tipped sideways or other in move and the drum is not on the runners.(Felt front and Bogey/rear)... (Some of these you can reposition buy lifting the drum up from the inside and adjust realigning)..
They can make a racket!
Jan 18, 2008 | LG DLE2532W Electric Dryer
Dryers Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
