Vacuums Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My riccar vacuum does not pick up anything - Riccar Vacuums
Anonymous
Level 2:
Scholar:
  • Expert 95 Answers
  • Posted on Oct 21, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
95
Questions
0
Helped
72066
Points
196
Check the belt and then the tube on the side of the vacuum that runs from the bottom to up the side to the bag. If they belt is broken the vacuum will not pick anything up. If that tube is clogged up with dirt that will keep the vacuum from picking up as well.
I have a Riccar Supralite Cordless that is clogged. I just replace the bag but whatever the vacuum picks up, it seems to be pushed back out. Is there a way to get to the vacuum tube to unclog it?
Start by checking the suction opening by the brushroll. Then remove the screws and take the nozzle cover off. Remove the cover to be able to inspect the impeller for clogs or debris. Pull the motor if necessary to gain access to the lower end of the suction tube/handle.
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Drive brush roller spinning in reverse, not picking up
The belt on an 8925 should not have any twist. If it has been twisted the brushroll will go backwards. Install a new belt and make sure it will spin freely with no twist in the belt.
Air not getting to hose
I'm not sure which model you have but this is good for Riccar upright vacuums. If the hose has good suction but is not picking up well check the suction tube that is down by the brush roll. The suction tube starts by the brush roll and goes to the back of the vacuum where you put the suction hose into. If it has a clog or restriction the vacuum will not pick up properly.
Hello, I have a Riccar 8000. The belt works, the bar spins, and it will **** things up. However, it will not pick up threads and dog hair or anything from the carpeting. Mu husband took the bottom off and...
The belt should be replaced at least once per year. They lose elasticity and will slip when vacuuming. The brush strips in the brush roll can be replaced. It is well worth having it serviced by a Riccar dealer,. The 8000 series can last many years but any long lasting vacuum will require routine maintenance.
2helpful
Absolutely no power. No light or anything. Is
There's a small white button on the back of the machine near the left wheel. Use a paper clip or similar item to push that in.
No suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
