I instruct the my computer to always ask for code before booting, but whenever it ask fo code before booting, i don't know how and where to insert the code. please, help me out.
If the Nokia 6555 asks for restriction code,it is locked to network.You need to unlock it to use with other network sim card.I would suggest you to get the restriction code from service provider and get free unlocking instructions from the site Mobileunlockguide.com and unlock it step by step.
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.
Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.
There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.
Click on one of these links todownload HIREN'S BOOTCD :-
http://www.hirensbootcd.net/http://67.20.82.163/
You cannot uninstall an operating system once it's installed. The only way to remove it is to reformat the hard drive (meaning erasing everything) and then installing Vista (if you have the isntallation disk that came with the computer). Now some PC's have a restore button like Lenovo or IBM computers where all you need to do is press that button and then it will reload the operating system and therefore erasing the one that's installed in your computer. For all other computer brands, you would need the Installation disk.
If you have the installation disk, just put the disk inside then restart the computer. As the computer restarts, continuously tap F12 to pull up the boot options menu. Then select " boot to optical/CD/DVD drive" then press enter and from there, just follow the instructions and you're good to go.
Note: You should always ask for the Installation disks for the OS (operating system) whenever you
buy one that came pre-installed with an OS. Always.
If that would be your case that the phone is always asking you to format the MMC, your MMC could have been damaged or getting into being corrupted, please try using another MMC, and reformat it, then re-boot the phone, see if that works.
If that works(your other MMC) it simply means that your MMC is corrupted or faulty, have it replaced (buy a new one)
I have been an upholsterer for over 30 years, I own a Pfaff 145 and Pfaff 545. Both are basically the same. Whenever my timing is off, where the threaded needle won't connect with the bobbin thread, I have always had success in re-setting the timing by taking apart the entire bobbin case. Remove the walking foot and the plate it walks on. Remove the bobbin and dismantle everything underneath it. Keep each piece and its screws together, and remember the order in which you removed it (last goes in first, etc.)Remove any obstructions, thread, fluff, etc. Surprisingly, when you put it all back together, your timing will be back to normal. This has always worked for me, and I hope it'll work fo you.
