SOURCE: My Toshiba Rear projection TV Has A blinking power light
The power supply is in protect mode. There is most likely a short on one of the boards, or the high voltage generator, or a scan amplifier, or the power supply itself has a failure. Without troubleshooting the set it is impossible to know.
Jerry G.
SOURCE: toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: I have a JVC AV-56Wp74 Blue power light on the
There are a couple of common problems this model has--one is easy to confirm.
How handy are you if I tell you to disconnect the convergence board to see if it is your problem?
The blinking blue light means the set is in protective shutdown, and I know a fairly easy way to see if it is your problem and how to fix the set if it is.
Let me know if you need help--I am here to help people and l know a lot about this set.
SD TECH
Testimonial: "this was very helpful thanks"
