SOURCE: 2 red lights xbox 360
hardware problem... when it over heated it must of melted somthing in it... mine did that too
SOURCE: i have one red light on my xbox 360 that is flashing
1 red light usually means a graphics chip problem. A reflow of the graphics processor usually solves this.
Give us a call / shout if you need any assistance.
FixMyConsole
SOURCE: XBOX 360 TWO RED LIGHTS FLASH
2 red lights is overheating and to get it fixed you will have to send it back to Microsoft and the waiting time is painful at 4 weeks, if you don't want to do this then you should fix it yourself using a good guide at home
Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
XBOX 360 Red Light error, or Red ring of Death RORD is a
very common issue, and can happen anytime.
There are different Error numbers related to RoRD, and appears on screen
starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair
guide available that covers this problem and also all other common XBOX
problems. You can get your copy XBOX 360 Repair Guide, you can download it and
get help to fix your console. Please feel free to message me if you need
further assistance
click here to download.....................
