Boss Rc 50 Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I keep the drum track playing continuously without being affected by turning the recording tracks off and on?
Michial Gueffroy
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Oct 21, 2009
Michial Gueffroy
Master
Level 3:
President:
Answers
1140
Questions
0
Helped
532211
Points
2214
Have you checked out the update here:http://www.bossus.com/gear/productdetails.php?ProductId=772
When i play the keyboard and record it. it does not playback what i just performed when i record drums it plays back fine only the keyboard. im using the mpk49
I'm not familiar with Reason 5, but many midi track recorders need each instrument assigned to different midi chanels to be heard back. Check the manual in how to assign the midi tracks. Also, the playback has to be through a unit that is multi timbrel capable. Good luck!
I recorded drums to the internal click track/metronome and drums are in time with metronome when i play it back with the click from the start of the song. BUT, if i stop in the middle of the song and...
I'd say the click track starts from exactly when you hit play even if you've hit play not right on the beat. There might be a setting or preference that can fix this.
Try rewinding back to be right on the beat and see if it syncs with the click
I have recorded 4 tracks and a rytham arrangement but when i try to convert to MP3 i get no drums?? Any ideas
For the drums to take effect you have to master the track before converting. The manual explains how to do this. Push "exit" and "utility" at the same time twice, then "play" and "record" (to start the recording of course).
Seperate tracks
They have to be recorded on SEPERATE tracks if you want to keep them seperate. It will be hard to do this live as if you mic acoustics you will still get some cross feed in the mics from the different percussions.
With an electronic drum set it may be even harder as they often only have a single mixed output.
The way the professionals would do this is to play the kick and record it on a track... and then play that track back and record the snare and hat each seperately on other tracks.
Once you have synced tracks of the parts, then you can mix anyway you want.
With electronic drums you COULD have two seperate modules to give you two seperate outputs, but that is a budget breaker.
1helpful
I have a BR-600 and when I record tracks over one of the drum patterns, it is getting into the habit of going out of synch when I play it back (usually after I have left it for a day and come back to it) -...
If you turn the power off between uses you will LIKELY have to resync the tracks. I doubt the unit remembers anything about sync to canned drum patterns once you turn the power off.
Try leaving it on and see if it acts the same.
8helpful
2answers
Boss micro br not converting all the tracks in the song to MP3
You have to "mix" the tracks to create a final work before saving the file.
1helpful
2answers
When bounce tracks on my micro-br there seems static going on
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
1helpful
Problems setting midi channels using KN3000 and Cubase
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Apr 23, 2009 • Music
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
