I have a Maytag refrigerator model msd2555dr
It is leaking in the front left side and seems to be coming from ice melting in the inside that accumulated on the bottom. I am thinking of putting a bowl on the bottom to catch any water. I'm not sure where the leak is coming from. From what I've been reading, it seems that the drain pipe could be clogged and the drain pan defective. Please advise! Thanks! -Tom
Hi tom
yes the drain tube may be glogged and when the unit defrosts the water just flows to the bottom of the un it then eventally out, if you have a clogged drain, you will see water on a pretty reglar basis
8, 10, 12 hours
the drain pipe is behind the back wall on the freezer, if you take that off you will se an ice build up, remove that ice and clear the drain tube
you may need to pull out the machine and remove the tube from the back to ensure that it is entirley clear
Testimonial: "Thank you for the advice milten1! I'll try it."
