Maytag Neptune MAH6500A Front Load Washer Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a mah4oooaww maytag frontloaded and sounds like the water is not draining removed pump and is clean and drain water still inside drumHow do i get rid of the water in drum
Anonymous
Level 3:
President:
  • Master 1,304 Answers
  • Posted on Oct 20, 2009
Anonymous
Master
Level 3:
President:
Answers
1304
Questions
0
Helped
367563
Points
3700
Jf you have removed the pump i can assure you the water is out
what you may be hearing is the liquid balance ring on the tumbler front
if it sounds like running water when you turn the tub, it means your balance ring is working'
it is there to keep the machine balanced and is sealed in the ring
I Maytag centennial it finish it cycle but it still sounds like the water is draining
If your Maytag Centennial washing machine is making a sound like it's draining water even though there's no water in the tub, it could be an issue with the drain pump. The drain pump is responsible for removing water from the machine during the spin cycle.
Here are some steps you can take to troubleshoot the issue:
  1. Unplug the washing machine and remove any remaining water from the tub manually.
  2. Check the drain hose for any kinks or blockages. If you find any, clear them out.
  3. Remove the drain pump from the washing machine and check for any clogs or damage. If you find any, clean or replace the pump as needed.
  4. Reinstall the drain pump and run the washing machine to see if the issue has been resolved.
If these steps do not solve the problem, it may be necessary to call a professional repair technician to diagnose and fix the issue.
What do we do after replacing the pump on an LG frontload washing machin, yet still get error message OE?
Assuming you cleaned the pump strainer?
Likely the drain hose leading from the pump to the drain, the section
inside the cabinet that "u-turns" back down is plugged up with
junk.. I had to remove the hose from the machine and force water
thru it at a outside faucet to clear what looked like a turd from the
inside of the drain hose..My shop vac could not dislodge it..
Won't drain and showing F 01
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
My Maytag dishwasher (MDB955AWS) will not drain ans is not cleaning the dishes properly.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back for any further assistance.
Daniel
When it hits the final spin it makes a cruching noise and will not drain
Sounds like you have a bad drain pump. Usually the impeller will break off the pump shaft and spin freely inside the pump causing the noise. You will need to remove the pump and feel inside and see if the impeller is broken. Be sure to have a shop vac handy to drain the water from the unit before removing hoses. If its a frontload remember there is alot of standing water in between the tubs. Good Luck.
_MJ_
2helpful
What does the nd Error Code mean on a Maytag Neptune frontloader??
ND== No Drain.
You likely need the drain pump cleaned. Unplug and pull the washer out. Remove cover in back. The pump is attached to the washer's floor. Pinch off the hose from tub to pump. There's going to be some water left in the pump and drain hose, so get a large towel ready. Remove screws attaching black piece (motor) to white piece (housing), pull out motor and clean the housing and motor impeller. Wear gloves, as it's always a nasty stuff what comes out. ;) Reverse steps to assemble the pump back together. If you don't hear pump running after completing all the cleaning, you may need to check the wiring and/or replace main control board located inside the console. If the pump seems to be running but no water is being drained - replace pump. for Maytag MAH5500B the part number is 25001052.
Vlad
First Choice Appliance
Can''t get my clothes out... water still inside
does it have a dial that you can manually turn to start the next cycle? You can usually drain the water by pulling the drain hose out from the wall drain behind hte washer....( usually just shoved in the drain not attached) but be aware that when you hold the hose below the water level in your washer it will start to drain. Then perhaps the door will unlatch.
Will not drain
If the drain lines are clear, test the drain pump, and see that drain pump is not clogged by removing it and cleaning.
If the drain pump is fine, then it is probably a defective control timer.
You can find machine diagrams and replacement parts by entering model number here.
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
The Maytag wahser stops and the door is unlocked
Something large in the drain pump could be the problem. You might need to remove it and take a look inside.
MAH2400AWW Frontload Washer drain pump removal link:
http://blog.myspace.com/index.cfm?fuseaction=blog.view&friendID=58843118&blogID=364038999
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
