Canon PowerShot A560 Digital Camera Logo
Posted on Oct 19, 2009
I dropped the camera the other day and now it is
I dropped the Canon A560 camera the other day and now it is not snapping the picture. A green box shows in the view finder but it does not snap the picture. I can view older pictures and the actual current image, but it doesn't snap the picture.
5 Related Answers
Anonymous
  • 216 Answers
  • Posted on Nov 27, 2006
SOURCE: Canon S1 IS view finder / LCD monitor black out
This is a defective CCD that Canon is repairing free of charge. Go here for details: http://www.usa.canon.com:80/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8044&keycode=2112&id=29819
Anonymous
  • 72 Answers
  • Posted on Aug 26, 2007
SOURCE: A95 Power shot Images on the LCD screen are monochrome,blurred with stripes
Unfortunutly this sounds like the cable connecting the screen to the main board is either loose or damaged. I would return it to the store you got it from.
poolseman
zdenek vajdak
  • 206 Answers
  • Posted on Sep 14, 2007
SOURCE: No image in view finder
Common fault with these models and is caused by faulty CCD sensor. Canon will probably repair free of charge so send it in . As I said very common with this model.
t00nz
CameraR
  • 4738 Answers
  • Posted on Nov 15, 2007
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Anonymous
  • 480 Answers
  • Posted on Jul 24, 2008
SOURCE: image through view finder is blury
Hey DarsCanonFix,
This camera does have a diopter adjustment on the viewfinder to correct for bad eyesight. I would try adjusting this since it could have been accidentally set incorrectly. If this doesn't work the camera might just need a good cleaning by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
When I plug my camera (cannon A560 powershot) into my computer using a USB cord, the camera screen goes blank and a green light blinks. I can't upload pictures on my computer anymore. I just recently got a...
Try NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Hello, I lost the disc for my powershot a560, can you help me? I'm on Windows xp
You can download Canon software from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a560#DriversAndSoftware
You might want to consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
I don't have the software to download photos from my canon a560 digital camera to my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Need upload dvd for canon a560 camera
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
In using windows 7, how can i view and download pictures from my canon powershot a560?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Will not transfer pictures to computer
4helpful
Can't Download A Large File from Canon A560 Digital Camera
Get a card reader. The one pictured below is $13 at Walmart. Create a folder on your desktop. Insert your card into the card reader and the other end into a USB port on your computer. Drag and drop the video file into the folder you created. b957eb4.jpg
Low or no power even with new batteries
when you dropped it, it may have nocked something loose.
Transfer image to computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Canon powershot A560
an incandesant light above the stones and the camera without the flash should work.. thats how i was able to capture the pink of pink saphirres...and zircons.. hopefully it works for u
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
