Check our Idler ( the black item right under he TPS at the trottle body) for function and clean them. If this don't works, check your fuel pressure (right cylinder bank, between 3. and 5. injector is a connector) you need 49 to 52 PSI. Check for stored trouble codes (ignition on, till bulb check is over), off-on four times, miles display will change in Trouble code mode. If there are any codes stored, you will get P and four digits, after finished you'll get "done". If there are no codes stored you'll get immediately "done" . If there are some codes stored, pleasy come back again with the numbers
replaced cam shaft senser had a po340 code. still havig same problm. also replaced plugs
replaced cam shaft sencer due to code po340. also replaced plugs and still having same problem. it also shakes and shutters till it dies
