Recently started having problem with door reversing before closing. Usually just hit the button again and it closes properly. Now, however, door goes all the way down, then reverses about 1/3 of the way up. Tried several times and it doesn't correct. ????
If the main light flashes 10 times when the door reverses it is a door sensor problem. Each sensor has a small light that must be on and not blinking for them to work properly. If one of them is not on tweak them a bit to make sure they are pointed at one another.
The stopping about 1/3 of the way up is either a broken door spring, a main drive gear that is going bad or an adjustment to the 'up force'. The 'up force' control is on the back of the motor unit near where all those white wires go. Increase it a bit. It will sometimes compensate for a gear that is going bad but if this is the case it will start doing the same thing soon.
