Added new ram- the machine acknowledges the new memory and then causes PXE-e61 media test failure - check cable... like its trying to network boot.
taking the ram out allows the machine to run just fine.
if it were incompatible, wouldn't it just beep and refuse to come on?
Incompatible causes random failures. (random code execution)
why guess what that means?, chaos is just that.
you bought the wrong ram.
or is used and not new, or defective.
you're correct PXE is network server OS boot strap. thin net.
my guess is the bad ram caused bad data reads and looks like PXE card there and is not there, but who cares, bad ram is bad ram.
this old PC is now retired at HP. zero support
did you ask Kingston memory for help? be like first.?
top answer at HP real your PC. (hp forum)
"stick to a good brand name like Crucial, Corsair, or Kingston."
it is 13 years old PC.
266mhz memory min speed.
the 3 original p/n from hp were
1024-MB
512-MB
256-MB
367775-001
367774-001
367773-001
it needs 2.5v memory. (or dual)
a common size is.
DDR
512MB-DDR333, 333MHz, PC2700, 200pin SODIMM, 2.5v, Sync
2slots
2GB max.
most these are old stock, not made now.
good luck finding memory for such and old laptop this old
some can be very hard to make work.
some are limited by density too.... due to MMC limits inside.
Most likely you have a slow or dieing hard drive that is why when as you state you add correct ram upgrade the unit fails to boot.
skip the ram and replace your hard drive with a new ssd (solid state drive)
https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/PXE-E61-Media-Test-Failure-check-cable-Ideapad-z580/td-p/1318353
SOURCE: Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
SOURCE: ACER 5315 IS DEAD ON BOOT UP IT DISLAYS
Sounds like it is trying to boot from network drive. Have you changed the bios boot order. If so, change it back to boot from hard drive first.
SOURCE: my mini dell inspiration laptop sends me an error
This error comes up if the computer is not able to detect the hard drive. Power off the computer. Power it back on and tap the number 2 key 4 - 5 times at the Dell logo screen. This will take you to the system setp screen. Check if you see any thing listed next to solid state drive. If you dont see any thing try reseating the hard drive. Here are the steps to reseat the hard drive..
If you see an entry next to the solid state drive. You'll need to reinstall windows on the computer. If you have been shipped XP you will need an external CD drive to reinstall windows. If the system was sen with ubantu try to download it to a usb drive and boot off it.
Rate if useful.
SOURCE: operating system not found
might there be a non system disk in a drive???
Check that before you do anything else.
Let me know what you find
thanks
a
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA
the leads from your
((motherboard to your hard drive)) make sure they have a secure connection
and are not faulty or just replace them they could be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error if
this fails to fix the problem
another
possible reason could be a memory dump you might be running to many programs at
the one time placing to much strain on the CPU also you might not have enough
RAM random access memory to check what is running when your computer is running
scroll to the bottom toolbar right click select task manager applications and
processes if you see something you dont need running select end now to check
how much ram you have click start right click on my computer select properties
you will see all of your computers details another way to check
how much RAM you have click start all programs accessories system tools system
imformation all of your computers imformation will be there
try uninstalling a few unnecessary programs then click start run
type cmd then type chkdsk/r/f which will scan for and attempt to fix
any bad sectors and automatically fix any corrupt files on your hard drive this
will schedule on a restart don
