GE Spectra JBP78 Electric Kitchen Range Logo
Posted on Jan 09, 2018
My heating element on my GE Spectra caught on fire. I have the new element to replace it, but want to be certain the problem does not run deeper. I have read that this is very common, but is the fault in the element itself (cracked insulation) or do I need to be concerned that this may happen again?
2 Related Answers
Anonymous
  • 16 Answers
  • Posted on Apr 21, 2008
SOURCE: Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Anonymous
  • 491 Answers
  • Posted on Nov 11, 2009
SOURCE: My GE Spectra heating element caught on fire today
IT CAN BE IF THE ELEMENT HAS NOT BEEN REPLACED FOR A LONG TIME AND IT SOUNDS LIKE THE TERMOSTATS HAVE FAILD SO REPLACE ELEMENTS AND TERMOSTATS AND YOUR OVEN WILL HAVE A NEW LIFE .
Leaking around heating element posts that protrude through dishwasher body
Some dishwashers like your model number are under recall for a potential fire hazard due to water leaking through the heating element posts onto the wiring.
Your serial number must begin with the 2 letters listed . Below is the list of recall serial numbers: FL, GL, HL, LL, ML, VL, ZL, AM, DM, FM, GM, HM, LM, MM, RM, SM, TM, VM, ZM, AR, DR, FR, GR
Call the phone # below or check out GE recall website. What GE does is replace the element and gaskets, unless there is burnt or arcing visible on the wires, they may replace the dishwasher.
www.geappliances.com/products/recall
GE has determined that an electrical failure in the dishwasher's heating element can pose a fire hazard. GE will provide a free repair to all consumers with units affected by the recall. We ask that you not use your dishwasher until it is repaired and to disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire.
Consumers who instead wish to replace their dishwasher with a new model can receive a rebate towards the purchase of certain new GE and Profile brand dishwashers. Consumers can use a rebate of $75 for the purchase of certain GE front-control plastic tub dishwashers, or a GE rebate of $100 for the purchase of certain GE front-control stainless tub dishwashers or GE Profile top control dishwashers. See the rebate form for eligible models.
GE is aware of 15 reports of dishwasher heating element failures, seven of which resulted in fire and smoke damage beyond the unit. No injuries have been reported.
The model and serial numbers are important, as not all dishwashers are included in the recall. Look at the inside on the front left side of the dishwasher tub to find the model and serial number.
This recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission, which will also monitor the effectiveness of the recall program.
Recall Hotline
866-918-8760
Monday through Friday, 8 a.m. - 5 p.m. ET.
Before calling, have the model and serial numbers on hand.
Customer Care
Should we repair heat element, or buy a new oven?
It sounds like your element is electric. When food drips on that element it can cause a heat spot on the insulation around the electric element and eventually burns through. You can easily replace that element for about $50 - $60. It requires about three hand tools and 15 minutes to remove old one and install a new one. You should be in business for another 14 years if you clean any drippings on the element itself.
2helpful
The coil in my oven caught on fire
You will need to replace the element, If it was just the lower bake element, it is a very easy repair, two screws and two wire connectors. UNPLUG the stove FIRST!!
1helpful
My GE Spectra heating element caught on fire today and completely disintergrated. Is this common?
1helpful
2answers
Does GE Spectra JBP68 have a fuse? Only 1/2 of range is working.
Your GE Spectra does NOT have a fuse, but it has a electronic control board, as well as elements. If both your elements heat up at all, then they are good. If you will contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service we can discus the issues with your range and I will attempt to get you back up and running again soon.
You may contact us from 7 AM until 9 PM CST Monday through Saturday for appliance assistance and parts.
We look forward to working with you.
Is the glass surface on my GE Spectra solid surface glued to the heat element frame ?
The exterior panel (stainless in my case) is "glued" by adhesive to a lower metal piece which attaches to the door. I know this because my front panel came unglued and there is no other means of support. I am buying a very expensive new front panel.
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
2answers
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
