Compressor shuts down on low sump pressure
Check blow down solenoid valve orifice
Air may be getting in the suction side of the pump head
Check the compressor belt
Check your blowdown solenoid valve. The unit will shutdown when low sump. because your unit need at least 20psi during unloaded to circulate the oil.
On a SSR? check for correct rotation direction!
Need more info, here - Model/Horsepower is a good start. Also, do you get low sump pressure on startup, only?
