SOURCE: aeg favourit- water not heating up
The solution from Bulgaria was the best!
I had the same heating problem. And yes one of the pins of the relay was completely burned...
After some soldering it did not worked. Than I directly conect two lines from relay during working of washmachine and ...
ant it start to work.
It is great thanks to all and thanks to internet.
See U in future
JoN
www.ateliersuzanne.cz
thanks for the input.
SOURCE: AEG Favorit 40650 dishwasher is
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
SOURCE: kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
SOURCE: Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
