Set was working fine yesterday, but today it did not turn on and when I hit the power on both the remote and the TV the Power and OPC light flash green. I have unplugged set and waited a few minutes but the lights keep flashing and set does not come on. Disconnected the DVD player and still the same. Checked the operation manual and did not any solution.
Appreciate any suggestions.
DMC99
Hey i have had the same problem but i unplugged the tv for awhile about a half hour and then plug your tv into a different wall outlet if you can and should work. It worked for me, i had it plugged into a surge protector then i unplugged it from there, let it sit of half hour then plugged into different wall outlet and worked. so try that and see if it works.
Get the usb (flash drive) and go to sharpusa.com customer support / product downloads / software download find your model# then select firmware (last 30 days) download files, save it and transfer files to usb flash drive. Unplugg the tv and put the usb on the back the tv, plugged back in and turn it on. Should work, for sure.
Have the same problem, but my tv did come on after a long wait (the wait seemed to get longer and longer), although right now I don't get an image anymore at all (just sound and white stripes).
same thing set recognizes power on but thats it i tried reset but nothing happens different
I have the same problem. when I turn on TV power and OPC lights keep blinking. I press power button agian on my remote. OPC light goes off - power light stays on. then after a min both lights keep blinking again. I repeat this four times and then TV comes on.
It seems like if 'TV is off for long time, it takes longer to come on. Power and OPC lights blinking more times. I have emailed to Sharp. Waiting for their response.
OPC and Power Light flash simultaneously and the power light flashes twice and then it starts over. I'll let you know if I find a solution. I think I read somewhere that it is a power supply problem.
Same deal, it started after I had it month and it was too late to return it to the store. Sometimes if I let it flash for a minute or so it will turn on.
Sharp tech support has no answers and said they never heard of the problem.
