Hello mr gwashburn
______________________________________________________
E64:
DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w
chip, etc.
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
When I turn on my xbox it comes up with a screen that says contact your support at www.com/support in several languages then at the bottom it has an error code of E64. Allso I cannot get the disk out of the xbox it will not open. I have checked all of the cables and they are all attached.
Thanks for your support
Gil
would you like to fix it yourself ? Or have a shop repair it for you? also check to see if it covered by Microsoft warranty.
